After fitting a second M2 drive I've lost access to a PCI-E port which was populated with my sound card, can anyone recommend a PCI-E X1 X4 Cable Extender (needs to be around 6cm long) ?
You know a 1x card will fit in any pci-e slot? It doesn't have to be a 1x slot. Did the M2 drive share bandwidth with the 1x slot so now you have used it as a M2 the pci-e 1x slot is now disabled?
