I'm looking to replace my old Honeywell analogue thermostat with a wireless one. Figure it's better to double-check then fry something by mistake .
It's in the hallway and it seems silly heating that room when I only care about the room I'm in. I'm thinking about the Salus RT500RT. It's cheap and seems to be rated fairly well; I know the Honeywell CM921 is better but is it really £100 better? If it is I'll gladly swap but in reality I just need it to turn on/off .
The thermostat's currently wired into a Potterton EP2002 programmer. The central heating is "on" constantly and controlled by the thermostat and the hot water on the timer, so I'm assuming the thermostat has a constant live. The wiring of the programmer is as follows:
(the mains were isolated!)
Cross-referencing to the programmer manual it looks like:
Taking the Salus manual and the manual from my programmer I've crudely connected up all the bits:
Does that look correct? The earth isn't used on the Salus so would be terminated/removed.
I'm thinking it's probably going to be easier to swap the existing thermostat in the hallway with the new receiver instead of just disconnecting it from the programmer and mounting the receiver in the airing cupboard with a new wire. Being in the middle of the house it'll be the best place for signal as well.
Cheers!
- Green/yellow - earth
- Red - live
- Blue - neutral
- Yellow - switched live
Cheers!
