That's not fair. Must've gone for a popular spec, or something. I ordered one for my sister on 23rd August, and it still hasn't arrived.
I think Dell've been having supply issues, from what I've read.
InwardSinging, could you try something for me?
When you go into the nVidia Control Panel and Adjust the Desktop Colour Settings, do any adjustments you make remain upon rebooting?
I've ramped the brightness down but the setting never remains. Every time I start Vista it simply reverts back to the default setting.
Don#t suppose you could try it on your setup and let me know?
Just tried Guru - it did stick when i reset it.
Thanks for that.
Guess its time for a driver re-install!![]()
Right, gone back to the 101.43 drivers that Dell provide and finally colour adjustments made in the nVidia Control Panel stick.
InwardSinging, try un-installing the drivers from Add/Remove Programs, re-boot into Safe Mode and run one of the driver cleaners. Then, try installing the Dell drivers, removing it and then re-installing the Bioshock Drivers.
Bit long winded but it might work.
