photos arent 5:4![]()
the answer is obvious
Correct they are 3:2
Not quite sure of your point as ws are 16:10 and non ws are 4:3
I would definitely go widescreen. I spend a lot of time in Photoshop as it's part of my job and having the extra width to hold the side panels is great as it leaves me more viewing area for the canvas.
How can it be in my mind if you're saying that you would need a 20" regular monitor to match a 19" widescreen?
If you're only going to use photoshop then it really doesn't matter which screen you go for, they're both around the same amount of pixels overall.
Im buying 19"..
Just im buying 2 so i thought my width would be fine just my height is not very good on 19" ws?
Didn't know it was that much for 20" screens!!!
In which case my 2007FP was certainly a good buy!![]()
