Finally someone who can figure it out, I can get it a bit lower if I use YUY2, but for now I am going to stick with RGB24, just to be safe...., will be encoding to .wmv at 1280*720 at around 12mb/s, that's megabits..., may even go up to 14....
The wmv format uses a YUV 4:2:0 colourspace. So recording in rgb only has disadvantages.
Will be capturing under 1 hour of footage so storage space is not a problem, and a core 2 quad e6700 will just about do realtime wmv encoding from uncompressed source at 840*480 wmv *8mb/s, so anything higher than that, which is what i'm doing, realtime capturing to wmv is not going to happen, hence captuirng uncompressed, so I hope I have explained myself now...
Your encoding should be way faster than that. I can encode 1280x720 @ 15Mb/s to H.264 at 25fps on my cpu using Avidemux. However the hdd is limiting the rate that the uncompressed data can be fed to my cpu so capture should be even faster.
