anyone tried these drivers on AGP cards? do they work?
"VisionTek Radeon X1050 AGP" = ati2mtag_RV350, PCI\VEN_1002&DEV_4153&SUBSYS_30001545
"VisionTek Radeon X1050 AGP Secondary" = ati2mtag_RV350, PCI\VEN_1002&DEV_4173&SUBSYS_30011545
System Set-up
AMD X2 939@ 2.2Ghz
HD 2600 XT
Core @ 800Mhz
Mem @ 2200Mhz
Cat 7.7
3DMark Score 4273 3DMarks
SM2.0 Score 1546
HDR/SM3.0 Score 1898
CPU Score 1640
System Set-up
AMD X2 939@ 2.2Ghz
HD 2600 XT
Core @ 855Mhz
Mem @ 2350Mhz
Cat 7.7
3DMark Score 4477 3DMarks
SM2.0 Score 1635
HDR/SM3.0 Score 2004
CPU Score 1644
System Set-up
AMD X2 939@ 2.2Ghz
HD 2600 XT
Core @ 856Mhz
Mem @ 2344Mhz
Cat 7.8
3DMark Score 4664 3DMarks
SM2.0 Score 1767
HDR/SM3.0 Score 2049
CPU Score 1657
System Set-up
AMD X2 939@ 2.2Ghz
HD 2600 XT
Core @ 800Mhz
Mem @ 2200Mhz
Cat 7.9
3DMark Score 4952 3DMarks
SM2.0 Score 1829
HDR/SM3.0 Score 2259
CPU Score 1687
CS:S (Default Clocks in all tests)
1280x1024 0xAA 16xAF
7.7 - 123.63FPS
7.8 - 129.52FPS
7.9 - 146.73FPS
The site was launched a few days ago
Southbridge drivers are only if you have a motherboard that uses an ATI chipset
yep...
System Set-up
AMD X2 939@ 2.2Ghz
HD 2600 XT
Core @ 800Mhz
Mem @ 2200Mhz
Cat 7.9
3DMark Score 4694 3DMarks
SM2.0 Score 1717
HDR/SM3.0 Score 2113
CPU Score 1691
System Set-up
AMD X2 939@ 2.2Ghz
HD 2600 XT
Core @ 856Mhz
Mem @ 2344Mhz
Cat 7.9
SM2.0 Score 1829
CPU Score 1687
looks like these drives are borked too for x1950pro agp users. dunno what ati is playing at, they really messing up now big time.
i can't see any differents from the 7.8 to the 7.9 driversLooks like ATi are loving the 2400/2600 long time!
plus when will they fix crossfire for bioshock lolAt least ATI Acknowledge it in the release notes so theres no nasty supprises
"Caution: Installing the Catalyst software suite 7.8 or 7.9 on a system containing the ATI Radeon™ X1950 AGP series of product may result in either the desktop failing to be drawn properly or the operating system failing to boot. It is recommended to continue using Catalyst 7.7 for this product at this time."
this is with Vista though it seems the problems are with XP.i can't see any differents from the 7.8 to the 7.9 drivers
wow!!!! i just benchmarked with 3dmark06 in xp. see results below...
3DMark Score 9023 3DMarks
SM 2.0 Score 3566 Marks![]()
SM 3.0 Score 4473 Marks![]()
CPU Score 2286 Marks
http://service.futuremark.com/compare?3dm06=3003689
this is the last one i did before.Erm, Gareth. Compared to what scores exactly?. I don't think anyone is going to remember your previous score except maybe jrodga2k5 as you two have the cards.
. Cheers Gareth.
