Its a rubbish electronic one!
Just an extension of the TCS / ESP system really, Think they call it EDL.
PS - Added you to xbox friends (jubags).
Yeah, and I call it crap.
Just drops power, that's not a LSD really.
I turn it off if I want a quick start (as much as can be turned off that is)
LSD is not the same thing as ESP.
LSD - Limited Slip Differential
ESP - Electronic Stability Program (I think)
LSD is something which is found inside the gearbox..
The electronic differential lock (EDL) permits smooth, comfortable starts on road surfaces that do not have a uniform coefficient of friction. If a wheel starts to spin, EDL brakes it as necessary so that power is transmitted to the wheel with the better traction. EDL reduces tire wear and works up to about. 40 km/h (quattro®: up to about 80 km/h). EDL is part of the electronic stabilization program (ESP) and the traction control (ASR).
What is EDL??
