i dare say the 7.2s will score 16 more points in 3dmark06 or something.
if you want the latest fixes/performance boosts for proper games then stick with the latest drivers.
.So Marc2003. Anything else you'd like to teach me today?.
ooh touchy.
edit: just to clarify, maybe i should have kept quiet as xp drivers aren't my thing. been using vista for months now. but for a clean install, i see no reason why not to use the latest.
.No problem Jimmy.
Even if they do work fine you can always try and bench different driver sets to see how well they fair in XP if you want to do your own research. I'd only do 6.11's to 7.9's though but you'd probably be best doing 7.1's and onwards. Some people are still using the 6.11's lol.
Im not sure if this is a joke or not, but with theNot quite sure what you mean, 'bench different driver sets'
 ill assume it was a serious question.
 ill assume it was a serious question.Im not sure if this is a joke or not, but with theill assume it was a serious question.
What he means is download a few different driver revisions & then install one after the other & bench each one in turn (ie run 3DMark or other software to determine which version gives you the best score). As the latest drivers are not always the quickest for every series of cards. Sometimes older drivers are better for earlier model cards as later drivers may sometimes implement effiiciencies only intended for the newest cards.
	Iam having problems, installing the drivers. Ive tried both the 7.2 and 7.9 version and get this message each time I start windows xp and if I try to open catalyst control center.
The found new hardware wizard starts each time win boots aswell, but it can't find the drivers.
 . It just looks like dual dvi to me and not x1950 pro dual. No one else picked up on that either, must have thought the same as me?.
. It just looks like dual dvi to me and not x1950 pro dual. No one else picked up on that either, must have thought the same as me?.ATI RADEON SAPPHIRE X1950 PRO DUAL DVI <------ That is the thread name and I thought it was just a x1950Pro with dual DVI.
I didn't know it was actually the dual card lol. Sorry about that Jimmy1983. If I knew it was the dual I'd have pointed you in the right place. It just looks like dual dvi to me and not x1950 pro dual. No one else picked up on that either, must have thought the same as me?.
