- 1 Sep 2006
Shamikebab said:right here, and its been on carpet all that time, on every day![]()
Ooh you maverick you, living close to the edge.
Win^ said:The one's that have received the xbox back, are they refurbished or brand new ones?
Mine has landed today and, according to the wife, it's an October 06 console where mine was Nov 05. It took around 20 days.
Whats more interesting is that mine had been opened and severly hacked around with when I was trying to fix the 3RLOD problem using the info on the net. You could clearly see where I had used a screwdriver to split (literally, half the pins were broke off 'cos I was frustrated) the case open.
So, either they are happy to replace 360's that have been opened for modification / fixing, or, much more likely, they aren't even checking them when they get them off the lorry.
Widget said:I would say brand new, the one I had today had all the stickers covering the DVD drive and IR port. This is the second time I have sent one off and the one I recieved previously didn't have the stickers on it. I also had to run the intial setup programme which I didn't have to do with the previous one either.
Tunney said:Mine was a refurb and still had stickers over the DVD drive and IR port. It was slightly newer, but definitely not brand new.
