- 8 Jan 2007
- Glasgow
lol, can't wait for this, finally my pc will be quiet
Heh, they are getting sneaky! Never even noticed they started stocking this, although did notice where the MX-1 disappeared tooArctic Cooling MX-2 Thermal Compound
I'll tell ya tomorrow.
just ordered one with...
Sharkoon Silent Eagle 1500 92mm Fan - 3/4 Pin
and I think my finger must've slipped...
Logitech G9 Gaming-Grade Laser Mouse - Retail
I think though, that the ram sinks have pre-applied sticky on them. Read one thread where a guy actual bought some different 3rd part sinks for whatever reason and used epoxy to stick them on.
I normally use AS5 but don't have any at the moment so thought I'd try something a bit different.
Probably won't post any o/c results as I've not even tried o/c'ing the card at all yet as I haven't really had the need to. but I will try and post some pics, thoughts, impressions and some temps etc.
Should be getting delivered to work tomorrow so will try and post some temps of my current setup tonight/tomorrow night and then fit this at the w/e and post the new results after that.
tbh at the moment I'm not too worried about temps, as long as it's not any hotter, my main aim is to make it quieter. Though I am going to keep an eye on CPU and case temps as well.
Still not sure which way I will mount it yet?
It can only go one way :s
must've missed the ordering deadline.
nope, two ways.
Problem is though which way? Bellow the card will block my PCI/e slots above the card and I might not have room due to northbridge and CPU coolers.![]()
What day did you select on the order page. If you selected Friday 21st September.
Then you should not have missed the order deadline, for todays delivery.
Here's some pics/stats before fitting....
The bits...
Case pre fitting...
1hr general usage
1hr Stress...
The case has x3 Noctua fans, one on the CPU cooler, one behind it on the back of the case (out) and one at the front in front of the drive cage (in). Also has another fan stood in the 5.25" drive bay blowing front to back.
The 1hr general use was me just browsing the web last night. I do have speedstep etc enabled in bios so the CPU wouldn't have been chucking out much heat.
The 1hr stress was done this morning while waiting for delivery.
Now just need to grow the balls to rip my £250 GFX card apart!![]()
I dont think he's actually fitted yet, as he said....88degrees!!!!!???
Did it have a fan actually on it? sounds like a damnd waste of money this, at 25% fan in my crappy case I only get to 90 degrees.
88degrees!!!!!???
