I dissagree.
On a decent rig Bioshock maxxed out will not even use 1.5Gb of Ram throughout the whole game. Same goes for Battlefield 2 and 2142. Therefore an extra 2Gb of Ram to make 4Gb will be of No benefit what so ever.
Vista does use more ram but still I havent ever gone over 1.7Gb of Ram when running any games. Running Vista SB x32 and XP 32bit.
).I disagree with you, having any less game optimized windows or windows with 500 mb of background stuff and you get bf2 to stutter on some big 64 maps when flying, while with 3 gigs it's fine.
LMAO is your vista borked? Vista ALWAYS uses 99% of your ram even if you have 16gb except completly at start when it's still cacheing (unless you disabled superfetch, but why on earth would you do that, it only takes a few minutes at start and for the following session you have an ultra fast pc and no unneccesary hdd cacheing).
Try CoH on ultra textures on a high resolution, not just the strat of theg ame record the usage while playign for 30 mins without alt tabbing ( it somehow clears the ram a bit when alt tabbing ), I had it pass 3 gb of usage together with my background stuff.
Besides, extra ram always helps when shutting down games in xp, you get to desktop much faster, also loading new maps ( once you're already playing) in bf2 is a lot faster with extra ram, as it keeps evrything untill you leave the server.
In vista, x64 or 32 bit, every bit of RAM helps, you will get MORE programs to start faster, more thumbnails and previews to load intstantly once you enter a folder, etcetc, imo 4 gb of RAM is DEFINATLY (a bit less in xp, but still very helful in xp) worth it ( ignore the sig, it's obelete).
Any good?!Ive never seen BF2142 use more than 1.5/1.6Gb of Ram and thats at 1680x1050, 4AA all on max details. I'm getting these results from the Windows Task manager under Performance and the Commit Charge values, either Peak or total. What are you using to gauge your ram useage mate?
I can't speak for CoH as I don't have it.Any good?!
. not even maxed all settings and reasoably low reso, but on ultra textures though)The amount of vram counts too. With bf2 it can need half a gig of texture space so if you have a bigger video card you will need less main memory
I agree 100%. Quoted for Emphasis.
Well use it as 3+GB in XP and when you feel the need for Vista gaming your all set with 4GB![]()
true, thats what im doing, ive already got vista but im not installing it until i get a game that uses directx10 due to the fact i see no other (current) advantage over XP, if you use over 3gb in XP though you can put the /3GB switch in the boot.ini (copy the line thats already there, stick /3GB on the end and you'll get a selection when you boot your pc)
although that still only allows me to see 3.5gb, what does it actually do?
