Back in June my car went into kwik fit with a blowing manifold (diagnosed by bmw) as they said they could change that. they told me it was actually part of the exhaust blowing, not the manifold, and having had bad experiences with most bmw main dealers i was perfectly happy to take kwik fit's diagnosis. so they replace the front section of the exhaust and the thing is still blowing. a few weeks go by, i was busy, i take it back and they replace out the exhaust again (under warranty) as it's still making noise. they also replace the heat shield on the cat, also for free. after all this is done, the boss of the kwik fit tells me it's the manifold that's blowing and they can't fix that. riiight... so why not notice that at the start? so it seems bmw were right but anyway.
that's the backstory. i take it to a local independant guy today and he fixes it, and tells me there's a bracket missing that should be holding the exhaust onto the gearbox! he also tells me that the bracket wouldnt fit with this exhaust, as it's not the correct shape. so. kwik fit have replaced my exhaust with a part that doesnt fit right, decided to bin the bracket that holds it in place, so if they don't put it back it's going to tear the manifold apart again.
what would your ammunition be, going into kwik fit, if they start to dispute things? the place where the bracket sits is clean metal, meaning the thing was removed recently, and they're the only ones that've been under it, so it is definitely them, but if they start disagreeing what would you do to try and persuade them that they need to do something? threaten courts, local press, that sort of thing?
