Thermaltake VA8000BNS
*subscribes to thread* I have the one with the window + 25cm and I swear it's just blowing dust into my case. It's very annoying and I too wouldn't mind getting it replaced with a solid door if I could find one.
there was a site i found a while back, gimme ten, i'll see if i can find it
pity Tt dont ship to the UK the ungrateful sods
edit: found one that does the windowed panels with fan (and with blue fan) for £20 :( pity you don't want to get the fan :p
i think it's nigh on impossible, i must have sifted through 60+ sites and all i can find is the panel with a fan on (either plain or neon) i only found the plain window once and it was from america (and i know can't find the link)
try mailing Tt, see what they say
edit: why not buy some perspex and diy?
I couldn't find a side-panel for mine either; but I had solid and wanted to mount a fan there, since my system was massively over-heating.
I cut out my own hole and mounted a 120mm fan + fan filter, keeps it quite cool now.
Now I'm looking forward to my new system and Antec P182 case.
Agh no lol, appears that you may have been able to get swapsies? Ah well..
