VIVO
10 Nov 2006
I've completely lost all cables which came with my X1900XT and there's no hope of getting them back.
Now I need to hook up my TV to my computer but I can't find anywhere that sells an adapter or the leads that I need.
I'm not asking for a link to a competitor, but can anyone tell me if it is possible to get an adapter like the one that I need? If so, am I better off looking on the internet (which i've had no luck with whatsoever) or the highstreet?
Any advice welcome, thanks :(
It is possible. What isn't, is hinting where.
Or of course put a bit extra to the cost, treat yourself to a new card and sell the original on.
Hmm, I'm not really in a position to be splashing out on a new card at the mo. I think I may have found what i'm looking for but I don't wanna waste more money on adapters that won't work so really I wanna make sure.
I thought the x1900xt just had a standard s-video out socket so you just need a s-video to s-video,scart or composite leads depending what connectors your tv has.
Afraid not. I thought it did so bought a S-Video to Phono adapter but the socket in the back of the graphics card is 9 pin and as far as I know, VIVO is the only socket with 9 pins.
The only VIVO cable i've managed to find just converts it to S-Video so the signal would go VIVO>S-Video>Phono. Would I lose any quality this way?
