nothing, it just checks if there's anything to boot from on the cd drive, then fins theres nothing and boots from the hdd.
I'm sposed to be putting the .iso file on the Cd right?
No
It should be burned as a iso
select image from nero
You are burning a data file, it won't work.
sid
you've lost me....
Use nero
Select burn from image
then select the iso as the source,
It will then go straight to burn screen and click burn there, now you have a bootable disc.
sid
Also, you were offering £20 a week ago not a tenner![]()
lol, just read the whole thread, you dont seem to be having much luck do you?
Just echoing what others have said really, from experience it looks like dodgy ram or not enough volts through the ram. Im not sure what the Gigabyte is like with its voltages but it wouldnt hurt to try putting 2.0volts through the memory just to make sure its still not undervolting.
If the errors are getting less and less (i.e. you can now install some drivers when previously you couldnt) then it looks like more volts might work.
But before that, do run memtest.
just wanted check something. Is memory "overvoltage" the same as upping the mem voltage?
If that doesn't help, try running the PC with just one stick of ram at a time.
