I would definately go for
And get the paint sorted.
A cage is overkill for road use, besides if you go for an exposed cage you should always wear a helmet.
Hate to say it but I'd probably agree with Fox depending on how much spare cash you have to play with. Although if you're loving the 'teg is there any point changing it for type r? Or a dc5?
[TW]Fox;10290872 said:This is like me fitting an M5 engine, M5 interior, etc etc.
No, it's not. The SiR and the Type-R are much closer than your car and an M5.
[TW]Fox;10290952 said:Get a DC5. Get a DC5. Get a DC5. Get a DC5.
[TW]Fox;10290762 said:I'm sure it's not a shed, but wouldn't you rather start with a perfect standard example first? The end result will be so much more pleasing.
Power is nothing without control
Not to mention a 10,000rpm NA screamer:
a) Going to cost as much as the car is worth.
b) Going to be pants in the real world.
c) Not going to be bullet-proof.
With an SiR if you want 250bhp you stick a turbo on it, they take it really well unlike the Type-R.
The all important question - how much for the new engine?
Stage 3 cams will just make you look like a driving n00b every time you try and park in Tescos
The spec:
B18c
LSD BOX
Polished head
2 Skims to head (raise compression)
1 Skim to block (raise compression)
Skunk 2 stage 3 cams
KMS retainers
KMS valves (Valves Re-adjusted to work with high spec cams)
KMS springs
Top line Oil pump
Top line Water pump
OEM Head bolts
OEM headgasket
All other gaskets OEM replaced
Skunk 2 pro series inlet manifold
Spoon pistons 11.6.1
Tuning Worx clutch (capable for 350BHP)
Aftermarket fuel rail
After market fuel regulator
10,000 rpm was just a figure I am bandying about to get the 'monster N/A' point across, I'm fully aware that this spec may not be good for 10k
I've got a BMI DVD on the SiR and Type R Differences, and I was under the impression there were quite a few...
I was under the impression the car was a track weapon.
