Macbook, Leopard, new HDD
18 Oct 2002
Bristol
I bought a MacBook 2GHz, 2GB, 80GB in Dec 2006. I’d like to upgrade to Leopard and also increase the size of the HDD. I’d like to use the 80GB in a USB2 caddy as a portable device and install Leopard on a new drive.
So questions:
Does the upgrade go on a new drive just fine?
Can someone recommend the replacement drive, I’m looking for a 7200rpm 160GB+ model.
Can someone recommend a decent USB2 caddy for the old drive?
Thanks!
Aparantley it doesn't eat the battery like people think it will. So you should be fine.
The Seagate has the G-Force thing that stops the HDD spinning if it's dropped iirc, but the Hitachi has more cache. They both have their advantages.
The MacBook already does that as standard, you don't need a special drive.
So go with the Hitachi.
The cost per GB is pretty much the same ~60p and I can't see the extra 40Gb really being worth an extra £24. The 160GB is already loads more than the 80GB in there atm.
The Hitachi 7K200 range are the best, and of those, the 100GB and 200GB models have the highest speed because they have slightly higher data density :)
