2nd hand Sanyo PLV-Z3
The Z3 is one of the best for short-throw image sizes.
Use this Projector Calculator to see image sizes for various throw distances for various projectors.
For reference - 7' throw = ~72" image, 8' throw = ~82" image with the Z3 on maximum zoom.
The Z3 also has the advantage of lens shift - meaning you can mount the projector practically on the edge of the projected image - and still have a square image!!
I'm sure a quick search should bring that up, I've had mine for ~2 years now and have only racked up about 1500 hours of use, so I've still got another year or two before I need to think about that!![]()
Most projectors don't have a scart socket on them...
However, the Z3 has an HDMI, VGA, 2x component, an S-Video and a composite connection (in order from best-worst quality) so you should be able to find some way of connecting stuff up
As for ease of setup - sit it down, point it at a wall/screen, plug in a mains cable and a video cable of your choice to the source of your choice, turn it on, select the input you want and adjust the image position, size and focus.
Then sit back and enjoy!
White wall paper, providing it's not too glossy/shiny, will do as a starter for 10 - but a proper screen will make a massive improvement.
Here's the setup in my room - the projector is above the head of the bed, on an old tv bracket. That's a 5ft wide screen, so about a 68" diagonal image
And from almost the same position with the lights off:
I've now got rid of the Sky box, I never really watched it, I've now just got my PC hooked up to it and I use the PC for everything![]()
Ive got a panasonic AE700e and would reccomend it or the 900.
What's that big white thing on the right? Can you move that, plus the fan, plus the stuff on top of the TV, and project it just above the top of the TV? It'll be much better to watch than having it up that high
Yep that's about right - my mate just picked one up last week from Ebay for about that![]()
