Any tips going from a Diesel to a petrol?
19 May 2005
Lancashire
Hi,
Ive only ever driven diesel cars, and this was only once a week for 30 odd hours total while i was learning to drive. I learned in a turbo diesel Focus and passed my test in it back in June.
Ive recently got a first car (Focus 1.6) which is petrol and I'm finding it hard to get used to. I don't think it helps that i haven't driven for months after passing but it also just seems totally different.
In the diesel i could maneuver the car slowly just using the clutch and no revs but i tried this last night when i was parking up and it stalled. What is best to do here?, find the bite then apply some gas and then lift the clutch a bit to move slowly?.
Another thing I'm struggling with is finding the bite. In the Diesel Focus i was told to raise the clutch until i felt a sinking sensation in the seat. The car would actually sink down slightly as well. In the petrol Focus the car doesn't move at all. I tried listening for the engine noise to change instead and this was a bit hit and miss really, sometimes id roll back slightly. Plus if Ive got the radio on the engines so quiet i wouldn't be able to use this method anyway. Is this just something you have to practice and eventually your foot will go to the right position subconsciously?.
Another thing i wanted to ask is what does "slipping the clutch" mean?, Ive heard it mentioned on the forum as something not to do but I'm not sure what it means.
TIA
Yeh with my petrol focus I had to give it some revs before bringing the clutch up about 1000-1500 i think, my diesel is great tho its got loads of feel and the car can set off without no throttle even up hills. dont worry about it you will get used to it in no time. I leant and passed in diesel and when i got car i went diesel > petrol > petrol > diesel never bothered me either.
Its all about clutch control, even the lowlyest of petrol cars can be manuevered on the clutch alone, it'll come to you with time.
Slipping the clutch is when you don't have the clutch fully up, but are letting it bite for a long time (so the clutch is slipping, and the rotations before the clutch are faster than after the clutch).
:D Gotta love OcUK, all my questions answered in 3 posts, cheers.
I don't think i slip the clutch, if I'm on a steepish hill and stopped in traffic I'd use the handbrake to secure the car and then lower the clutch until I'm ready to move, is this correct?.
Saying that Ive not really been in any traffic in my car, Ive been waiting till the roads are quiet then going for a drive to get used to it.
I went out on this NSL road on thursday night and noticed the headlights were only lighting up 6' in front of the car. I'm going to have to find somewhere flat tonight and then adjust them to point up a bit.
I had the same problem initially for the first couple days.
Learnt in 1.7td corsa around 30 hours, then got a clio 1.2 petrol a few months after passing. I too used to just use the clutch with the diesel, but in the corsa I'm applying some revs as I raise the clutch to achieve the same movement. You'll get used to it fairly quickly.
Yep, except if you're waiting for a long time (longer than about 5 seconds) put it in neutral, less wear and tear, and less effort required keeping the clutch to the floor.
I have friends who hold the car on hills by slipping the clutch and it drives me mad :mad:
Remeber, diesel engines are upside down.
7k rpm is where its as. All this bloody low down turbo induced torgue running out at 3k rpm is a load of boring crap.
I mistakenly bought a "performance" diesel and it bored me silly. Stick to petrol, its the future!
To be fair I can change up at low revs in my 2L Honda and it'll be fine for town driving, just not on the open road ;)
If it's a 2.0L petrol, then yes you do. Although that would depend on your definition of "making progress" I suppose.
Reach the speed limit / appropriate speed for road within a resonable time period. Only really drive through town or on the motorway so i see no point of driving the nuts off it, not exactly going to have any fun.
Driving my girlfriend's Ford Fiesta petrol zetec feels like its coming home where it belongs...Thats how it feels, I am not sure I will buy diesel again as my next car.
