 ) and then fix.
 ) and then fix.It is nothing sinister, it is a test and has to be fixed within 10 mins. The RAM out of the slot is something I have thought of.
As title really! I need to break a PC and then the problem sorted with a simple solution.
Suggestion please.
flick voltage switch from back of your psu to 120v from 240v (if you is european). the psu will blow up.
and ot fix the problem, just buy another psu. simple method of breaking pc, and simple method of fixing pc.
in the job interview they want u to break it then fix it? Surely you can do raelly stupidly easy thinsg then like pulling ram out then back in again. How pointless.
What about the rest of the pc? Surely tahts not going to like having such a jump in volts?
How about move the CMOS jumper to the "clear" position. It won't boot then
Genius!just overclock it soits unstable and crashs at boot up and then reset the cosmos.
