just wondering what i would expect to be different then an average pc laptop
I wouldn't mind an Expresscard slot, every other laptop on the market has one, why can't the MacBook.The only thing I wish they'd include is an integrated card reader.
Then shuffle things around a bit? I wouldn't decide to release a laptop without a hard drive because I ran out of space for it when I was designing the machine.Not too sure but based on the Battary, HDD locations and how tight the mobo is, for the size, an Xpress Card slot isn't going to be a possibility...
It's obvious that Apple do it to artificially limit the MacBook in comparison to the MacBook Pro
Where do you propose they add an expresscard slot? or any other additional hardware, remembering that all the space at the bottom is used by the HD and battery, there is no way to fit anything else in without making the battery smaller and killing the battery life.
If Apple had decided to include it, they wouldn't have designed the current MacBook and then stuck an Expresscard slot on the bottom, they would, you know, have designed it into the product..
The MacBook isn't such a compact machine...
Mate please lose the rose-tinted specs, it's 2.31kg, a long way out of ultra-portable territory, and is only a touch smaller than the 15" MBP.Yes it is.
...because Apple has it on the MacBook Pro, and it's another reason to tease people to part with the extra cashI wouldn't mind an Expresscard slot, every other laptop on the market has one, why can't the MacBook.
