I've rec'd Nokia N95 8Gb
[TW]Fox;10341837 said:
Number not recognised :(
Bah humbug, sorry. I used a site called 192.com which we can use at work to find numbers. Maybe they got so many calls they've changed/disconnected the number.
Did it work ?? cause i'm coming to the end of my contact and am wanting this or rthe 850i
had a play with the n95 and it seemed slow and clunky in the OS
Nah, I think it does nothing at all - its a bit of a rumor. The N95 8Gb is far quicker than the N95 - however for a smartphone the N95 was quite zippy.
Well the boot up is definately quicker and my friend reckons he can notice some speed difference but I don't know if its a placebo or not.
A SIM Free model is going to be at least £400 though, which is approaching your contract buyout amount.
£499 I hear :(
My buyout amount is £420.
Then I'd have to pay £150 for the 8GB phone which gives a total of £570.
I reckon I'll be able to grab a sim free phone in a week or so for less than that, and stick with Orange.
I used to be with Vodafone but found I had reception problems at home, which annoyed me no end and was part of the reason I switched.
My god phone shops are awful.
Now trying CPW. Can I simply ring a number and a guy at my local shop picks up? No way.
I'm on hold to some random call centre and have been for 22 minutes. I only want to know if they've got any left!
Edit: They answered, and dont actually sell Vodafone. Which means the guy in the shop I spoke to who said he was getting 'loads' in stock on Friday was.. a liar. Great.
I suspect if you call up on Friday you will find customer service agents will know more - until then they will try and blag you off like usual. Rest assured its out on Friday on Voda.:)
popped into my local voda store today and picked one up for £150 on a £35 a month plan, not had a chance to play with it yet still letting it charge :( although I was the only person to go in and buy one today and they had plenty of stock
How much was it on other plans, do you know?
as above it was the same prices as quoted on their site, had a chance to have a little poke around now its charged and i found a full version of spiderman 3 which was nice of them :D
I didnt say it was small :confused:- just that it certainly isnt a brick.
It depends how you feel about such things, it's huge if you ask me, brick sounds bad, but it *is* big. Yes it does a lot, but its still huge. Especially the N95 8GB since it has a decent sized battery this time as well...
If youd agree that the K750i was a brick then I'd see sense in what you are saying. Yeh sure its big its a capable smartphone as you mentioned (the 8b version is 1mm thicker). It maybe that as an owner of an N95 for 8 months I got used to it. I'd consider a brick a Tytn III, ie most HTC phones for that matter. But it depends entirely what people want I guess.
by the way guys the Voda version has VOIP disabled - this can however be avoided by installing Fring.
The K750 is a good bit smaller. The N95 is nearly 1cm wider.
