Bah humbug, sorry. I used a site called 192.com which we can use at work to find numbers. Maybe they got so many calls they've changed/disconnected the number.[TW]Fox;10341837 said:Number not recognised![]()
Can you buy these sim-free? Aren't they exclusive to Voda, it's their answer to the iPhone.Any sign of any sim free models in stock anywhere I wonder?
Did it work ?? cause i'm coming to the end of my contact and am wanting this or rthe 850i
had a play with the n95 and it seemed slow and clunky in the OS
Its almost the same dimensions as a k750i )just a bit wider (Not thicker) ie it isnt the brick you think it is.
A SIM Free model is going to be at least £400 though, which is approaching your contract buyout amount.
It still weighs 30% more, so it may be small (by your terms) but you won't miss it in your pocket!
There should be a speed difference, it has twice as much RAM.Well the boot up is definately quicker and my friend reckons he can notice some speed difference but I don't know if its a placebo or not.
popped into my local voda store today and picked one up for £150 on a £35 a month plan, not had a chance to play with it yet still letting it chargealthough I was the only person to go in and buy one today and they had plenty of stock
The prices are on the website[TW]Fox;10344032 said:How much was it on other plans, do you know?
I didnt say it was small- just that it certainly isnt a brick.
Good luck finding a legit seller.Go on the 'bay and you can get these unlocked for £290 "Buy it Now".
It depends how you feel about such things, it's huge if you ask me, brick sounds bad, but it *is* big. Yes it does a lot, but its still huge. Especially the N95 8GB since it has a decent sized battery this time as well...
If youd agree that the K750i was a brick then I'd see sense in what you are saying. Yeh sure its big its a capable smartphone as you mentioned (the 8b version is 1mm thicker). It maybe that as an owner of an N95 for 8 months I got used to it. I'd consider a brick a Tytn III, ie most HTC phones for that matter. But it depends entirely what people want I guess.
by the way guys the Voda version has VOIP disabled - this can however be avoided by installing Fring.
