BIOS Problem
26 Sep 2007
Amsterdam
This isn't a serious problem but when I load up the BIOS everything is shifted to the left, as if the monitor hasn't auto adjusted. Any ideas? Does this with another rig aswell.
My monitor has no adjust feature AFAIK, just auto adjusts itself. Specs -
E2160
eVGA 650i
2GB OCZ PC2-6400
x1950 Pro
Monitor is an Asus VW193S
This problem only arised recently.
did you recently update any drivers? if so, maybe try rolling back to the previous version - its odd for this to suddenly start happening on its own.
Drivers don't have any effect on the BIOS since you get the BIOS before your OS begins to load. See if there is an 'auto-adjust' option on your monitor.
