just finished the demo on vista 64, it did required me to download a vista update which i did but didnt give me any problems in running the .exe though
Nice pink text in your sig lol.
Tbh I cant even get the game to run on the 64bit exe, it hangs most of the time so I just stick to the 32bit one.
Is there any performance or visual increases between the 64bit and 32bit versions of the launcher?
The game worked fine on the 64bin exe for me..but not the 32bin exe lol.. weird
Cant call it a hotifx but if you are using the 169 beta, uninstall them and try the 163.71 drivers. I got the 64bit version to work with these. The game didnt hanged once but performance issues are another matter, at least you get to play it.
To improve performance, use the tweak of alt tab and setting the crysis.exe to high in processes. I got a huge jump in fps.
