It's been revealed that the new 40GB PlayStation 3 features more than just a cut down hard disk drive. Sony has also thought to stick the 65nm version of the Cell inside the new console, reducing the power usage down to around 135 Watts (down from 200 Watts.) That means the console also runs cooler and quieter, which is always a plus for a device that usually resides in the living room. Sony also jiggled around a few other components by making the heat pipe smaller, swapping out the motherboard for a new version, and added a button battery to keep time when the system is off. Looks like potential PS3 purchasers will be looking forward to a less noticeable din then.
Link
Has cut down the power usage quite a bit, probably much quieter under heavy gaming also! Probably saves some money if your folding 24/7 also.
Beneath every cloud is a silver lining!
Josh
, you're right about the PS3 pumping out more heat. I've only had mine since last friday, but the console pump out huge amounts of hot air, even after just being sat in the dash for a while downloading.
