How noisy r the fans??
when it boots from cold its really noisey, after about 40 mins it goes quite, r they ment to be like this? only fitted it wed
My old ATI x1900xt-x use to max out the fan on boot up....why does max out on boot?
I think it because the fan control is done by the GPU drivers...So the fan can't slow down till the drivers has been loaded...
It probably runs at full pelt on startup so you know its working, they are that quiet id be worried if i never heard it when i switched on.
its because the fan control on nvidia cards is controlled by the drivers hence why during post or in dos the fan runs full pelt, even in windows with no drivers installed it runs full pelt.
I can vouch 100% that without windows loaded or any drivers these cards do not run at "full pelt" after about 3 or 4 seconds i can happily browse through my mobo's bios screen without hearing it at full pelt. even when the bios is posting and finding all the connected drives it doesnt run at "full pelt" its writtent to the bios and not the drivers.
