Xbox 360 VGA Cable - How to get sound via Headphones?
19 Oct 2002
Scotland
As above, if i'm picking up a 360 VGA cable, what do i need to be able to plug a standard set of headphones into the xbox/or speakers.
Should make it louder and quieter depending on which way you move it.
The other option is i bring my big PC speakers and plug my headphones into them but i think Psymonkee will cry if i try and put them in his car along with the rest of my stuff :D
yeah, inline volume controls are just variable resistors and adjust the amount of the whole signal you recieve at the speaker. The volume is not boosted by them. Best bet is to feed the signal into the line in on a PC then have headphones hooked into that.
How do you do that with the VGA cable? Would i need anything else apart from the VGA?
on the end of the cable is the VGA, plus L and R phono socket's. You should get an adapter in the box (assuming its the official microsoft one) that converts the 2 phono's to a 3.5mm stereo jack. just simply plug that bit into your pc's line in (or some other kind of amplification device that hasnt got phono connectors on it) :)
