5 Nov 2007 at 12:15 #1 Virdi Virdi Soldato Joined 11 Jun 2004 Posts 4,232 Location Middlesex, London Hi all, Why can't you create a folder called 'con' in Windows?
5 Nov 2007 at 12:16 #2 AJUK AJUK Man of Honour Joined 14 Nov 2003 Posts 10,949 Well I never! What's all that about?
5 Nov 2007 at 12:21 #3 Didzi Didzi Associate Joined 19 May 2004 Posts 201 I think it relates back to the DOS days when the word "con" was used for "console"
5 Nov 2007 at 12:21 #4 Carter Carter Soldato Joined 27 Nov 2002 Posts 3,105 Location North Yorkshire How weird, seems like there is a fair bit of info on google. Never heard of this bug before.
5 Nov 2007 at 12:23 #5 Didzi Didzi Associate Joined 19 May 2004 Posts 201 The same is for "prn" and "nul"
5 Nov 2007 at 12:27 #6 basmic basmic Permabanned Joined 10 Apr 2004 Posts 13,122 Location Darlington, County Durham For fun, install Windows 98 on a machine. Don't install any updates, or anything. Now try this: Start menu > Run > c:\con\con.exe Should result in a BSOD. I remember when people use to play a sound called c:\con\con.wav in IRC, and half the room would drop like flies.
5 Nov 2007 at 12:43 #7 bledd bledd Don Joined 21 Oct 2002 Posts 46,863 Location Parts Unknown if you make a ping testing file called ping.bat that doesn't work either (at least it didn't used to)
5 Nov 2007 at 13:18 #8 Burnsy2023 Burnsy2023 Man of Honour Joined 17 Nov 2003 Posts 36,750 Location Southampton, UK bledd. said: if you make a ping testing file called ping.bat that doesn't work either (at least it didn't used to) Click to expand... That works in XP. I never knew about that, very interesting Burnsy
5 Nov 2007 at 13:21 #9 oddjob62 oddjob62 Soldato Joined 8 Nov 2002 Posts 9,128 Location NW London bledd. said: if you make a ping testing file called ping.bat that doesn't work either (at least it didn't used to) Click to expand... That's because the batch file tries to call itself.
5 Nov 2007 at 13:23 #10 randal randal Soldato Joined 1 Oct 2006 Posts 14,695 copy con config.sys etc... springs to mind, ah those where the days. F6 to EOF... basmic said: I remember when people use to play a sound called c:\con\con.wav in IRC, and half the room would drop like flies. Click to expand... Quality
5 Nov 2007 at 16:02 #11 fail at the internets fail at the internets Soldato Joined 29 Mar 2007 Posts 3,827 Location Essex
5 Nov 2007 at 16:04 #12 badbob badbob Permabanned Joined 27 Jan 2006 Posts 7,288 ha ha you lose. That isn't windows folder.
5 Nov 2007 at 16:11 #13 fail at the internets fail at the internets Soldato Joined 29 Mar 2007 Posts 3,827 Location Essex No sorry you're right it's a mac folder..
5 Nov 2007 at 16:20 #14 Rebelius Rebelius Soldato Joined 14 Dec 2003 Posts 3,145 Location Edinburgh try creating C:\WINDOWS\con - if C:\WINDOWS\ is where your vista is installed.
5 Nov 2007 at 16:26 #15 JaffaJedi JaffaJedi Associate Joined 6 Apr 2004 Posts 722 Location Lost EDIT *scrub this I cant delete it now
5 Nov 2007 at 16:33 #16 JaffaJedi JaffaJedi Associate Joined 6 Apr 2004 Posts 722 Location Lost yay it works now to make con dir mkdir \\.\c:\con to remove rd \\.\\c:\con
5 Nov 2007 at 17:04 #17 Muffin` Muffin` Caporegime Joined 21 Apr 2004 Posts 33,237 Location Bristol Alt181 + con
5 Nov 2007 at 17:25 #18 gumbald gumbald Soldato Joined 26 Aug 2006 Posts 9,726 Location 62.156684,-49.781113 alt181? = Á?
6 Nov 2007 at 09:07 #19 Uhtred Uhtred Soldato Joined 18 Oct 2002 Posts 6,372 Location Bedfordshire also try NUL, COM1 to COM9 and LPT1 to LPT9
6 Nov 2007 at 09:09 #20 Uhtred Uhtred Soldato Joined 18 Oct 2002 Posts 6,372 Location Bedfordshire badbob said: ha ha you lose. That isn't windows folder. Click to expand... it's not possible to create those folders anywhere in xp, not just c:\windows
