What's the score with buying internationally? Could I buy from the USA and take advantage of the rather excellent exchange rate at the moment?
It'd be over the 'gift' limit, and, if you took a quick flight it would be somewhat odd: "Yes, I took my desktop computer with me..."
There are services available where somebody buys the item for you in America and ships it via USPS to you marking it as a "gift".
It would still be over the value limit of a gift if they check it though?
Yes. And as they come with no keyboard you wouldn't need to worry about not having a £ sign.
# is on a key combo, I would mash buttons to say which one but that won't help on a PC.![]()
The position of the # really ****** me off on the mac actually, I use the # A LOT for my job, and Option + 3 is not ideal, and I don't want to swap keys cos then it wont be labeled correctly and that would annoy me too![]()
It doesn't bother me too much, don't use it as often as you though.
Aye, and you live three hours drive away![]()
As the unladen European Swallow flies, Skully is around 140 miles away from me on a heading of approx 290 degrees.
In other words, he's both north and west.
Option + 3 is # on UK Macs, but don;t that mean that Option + 3 is £ on US Macs? I'm sure the £ is in their keyboard somewhere, and seeing as Shift + 3 is # for them, that leaves Option + 3 open for a £ sign right?
The pos of the # really p*sses me on the mac actually, I use the # a lot for my job, and Option + 3 is not ideal, and I don't want to swap keys cos then it wont be labelled correctly and that would annoy me too![]()
Now what?
