Alec,
This might be a bit irrelevant but i had trouble with my E4500 limiting at 334MHz FSB before i reseated the CPU a few times which gave me 360MHz, strange board the P5K Vanilla.
What memory are you using?
Ah thanks for the heads up.
Alec,
Id say atleast that... probably 3.2ghz +What sorta clocks would I expect with a rig like this? I'm not sure if I'll order it this month. Might wait until Xmas sales, etc.
I'm hoping around 3GHz.
I don't mind if it sounds like a jet taking off ;D
Nah, go for the geil, far far lower fail rate, ive had to RMA my ballistix RAM 3 times already, since july, and its more expensive. Madness to get it, besides the geil RAM will potentially get you up to 4ghz at stock....is more than that really needed ?Ive got pc6400 ballistix running on a P35-DQ6 at 1125ddr with +0.25 (above default 1.8v), I bought this ram cause it had a good reputation for overclocking. Crucial also has the best RMA service also having the returns dept. in the UK you cant lose.
Im not running 1:1 since the motherboard doesnt like to go over 395fsb (cpu wall?), but I have the ram at 2:3.
375 x 8 = 3Ghz with my e2160. 1.4125v
Leaving it at 2.8 would be silly, I'm gonna go for 3.2 if possibleYou leaving it at 2.8 then ? personally id try get it to atleast 3ghz before doing a very long stress test.
