Got it, installed it, cant play it!
I keep getting an error saying
'wargame-g4wlive.exe has encountered a problem and needs to close'
Anyone else getting this ??
Ye i'm getting that m8, happens as i'm in the settings screens before i even get to play
Just looking into it now, updating drivers, defrag Google![]()
Looky here m8 might find some thing usefull ?
----------> gearsforums
If not that particular post then go to the main directory and snoop about, i'm off to try a few of the ideas![]()
Check the Epic forum if your looking for advice - nobodies found any solutions yet. Ive just finished my reformat so I'll get it installed soon and get some picsThe graphics are better than the 360 I think
same error here. loads of reports on epic forums.
it says try cat 7.8's here http://forums.epicgames.com/showthread.php?t=583169
but sod that tbh and it doesn't seemed to have helped many people
I am on omega 7.10's (as cat 7.10's caused cryisi demo corruption for me) on 1900xt and xp
OK seem to have sorted it here Fingers x-d
I kept everything the same drivers, XP, overclock etc but un-loaded windowblinds and the game started ok, i played for the first 5-6 checkpoints then left. No crashes, how wierds that ?
what do you mean by windowblinds?
I immediately thought they didn't look as good (maxed out on 1280) but I haven't gone back to look at them on my 360
