Psu help
17 Oct 2004
Derby, UK.
Heya,
Im about to build a new pc since my last one died and ive not really been into building pc's and stuff for awhile so im kinda of out of the loop on whats good or not.
Im planning to use http://www.overclockers.co.uk/showproduct.php?prodid=BU-067-OK
with
http://www.overclockers.co.uk/showproduct.php?prodid=GX-064-OK
and the only problem I have is choosing a psu to run it.
I currently have http://www.overclockers.co.uk/showproduct.php?prodid=CA-061-AN
Would this be good enough to run this setup or should I buy a new one?
Any help would be appreciated, also any advice on different parts to use would be nice.
Thanks <3
are you planning to run SLI? What gfx card have you got? also as much as it pains me to say it (amd fanboy) you might want to check out the intel C2D as they are best value for money at the moment. :)
At the moment im not planning to run sli, im on a pretty small budget. In the future I will but im in no rush.
Thanks ill check them out :)
