Generate application list
18 Oct 2002
Yorkshire
Looking for some free software that'll generate a list of installed applications etc on my PC so I can use it to tick off what i've got to reinstall when I format.
Any ideas ?
http://www.listmaker.cc/
Listmaker, in the options - list preferences, set it to generate a list using folders only and only root folders. Then point it at c:\program files. Also point it anywhere else you may have stuff installed. Not exactly what you want but does a decent job.
Add and Remove programs? :p
I knew someone would post that :)
ok smart arse how can I print off the list off installed applications? and don't say take a screen shot :D
Thanks will take a look
