*Gears Of War* Thread :o) Game Pics & Performance.
Just tried to load up a saved game and says there is non saved?? And it wont let me login to Live says unable to connect! Anyone no how to sort this? So i have to be logged in to save my game ? why cant m$ just make things simple for once..
i could nearly sware the was a crosshair on screen on the 360 but it seems to be missing for me. Also when i 1st started the game it look crap, everything was set to low. i had to go in and up everything to Medium and it still doesnt look like the 360
E6300
2GB RAM
Vista 32 Bit
X1950 Pro 512MB
:confused::confused:
anyone?
Can anyone help me at all ?
It still wont let me login to Live :mad: this is really damn annoying that i can play but cant save the game unless im logged in!!
ox8015190a is the connection error im getting.
Have i got to change something in the router settings or something ?
Any help much appriciated
thanks.
thanks.
I got a connection error at one point then I went back and into it agian and it connected fine, I had to manually create a new gamer profile by logging into my windows live account for it to save checkpoints though.
really nice game this
if the multiplayer was like any other online fps, without all the xbox live gold activation crap, it would be a lot better
Print Screen for screenshots !
I must have deleted the My Games folder at one point hence the issue! hmm perhaps anyway...
Played the game now, in DX10 mode with everything up on highest (no FSAA though, I see no need for it) I'm getting an almost constant 60fps - no stuttering at any point either and again as with COD4/Crysis etc load times are record breaking!
I like!
I have used the print screen button, but where are the picture files sent too as default... Thank you for your help..:D
