Hi all,
After a while saving, I am finally in a position to buy a MB.
Few things i want to run by you experts
before I get it:
- I was going to buy the basic spec mac, upgrade the RAM and HDD from OcUK and buy an external hard drive for backups.
- However, now I am thinking about upgrading just the RAM, sticking with the standard HDD and buying a big-ish external hard drive to store my music, photos, and about 50 dvds.
In this scenario, the internal HDD would be just for apps.
Do you see any problems with scenario 2 in terms of streaming dvd films from a firewire/usb HDD, and the internal HDD being big enough to hold my apps.
Would I be better sticking to my original plan.
Sorry if my posts a bit of a mess, I just think if i'm buying a brilliant machine, why not do brilliant things with it
Cheers for any help you can give me.
Matt
before I get it:- I was going to buy the basic spec mac, upgrade the RAM and HDD from OcUK and buy an external hard drive for backups.
.Cheers for any help you can give me.
Matt
The quality is ok for me, you may not like it though so rip one to 700 and see, if you don't like it, increase the quality.
