get a 360 instead. none of this configuration lark. just set the display resolution to what you what and off you go. it just works![]()
Thats pretty much what you do on the PS3, not sure why the OP's looks that Jaggie.
Here's a pic - http://www.dmcelectrics.com/IMG_1025.JPG
The res looks awful imo - and that's a static image. It looks like that when I play it.
Or..
Does that look okay and I am expecting too much?![]()
that blatantly isnt being rendered at 1080p. did you try what i suggested?
put that foot down!
...and then run for the hills!
lol - you know how it is..!![]()
yes. yes i do
turn 720p and 1080i off and see what happens
difficult to tell. each game might be different. if its like ratchet and clank, it'll look worse. its really a try it and see. if you google for "cod4 720p" you'll find a few references to problems with 1080p output. its a weird issue i have to say, but they may fix it with an update at some point.
the PS upscaler and smoothing only apply to emulated ps1 and ps2 games![]()
Thanks for all your help mate - I'm a happier man than I was 4 hours ago!
Plus what are PS Upscaler and PS Smoothing
well you have a 37" tv, and i an guessing the resoluion is liek 13XX x 7XX
so why use a 1080p output. leave it at 720p.
and truthfully, to the naked eye, untill you go into 50" screens, or you sit like 3 m away from the tv screen, you cant tell the difference between 720p and 1080p
Ha! I was only saying to myself last night that there's no way CoD4 can look as good as it and run at 720p (especially on the PS3). It's getting slightly ridiculous as MS's rule of every game must run at 1280x720 is being disregarded left right and centre.
