- 4 Jan 2004
- ¯\_(ツ)_/¯
I recently got one of those headunits which has a USB port in the front (FWIW, it's made by silvercrest, the onboard amp is poo, but the pre-outs sound good, so I'm using them).
I normally use a 1gb pendrive filled with MP3's and OGG's, and it works well...
I fancied having a few more songs however, so I threw a 250GB in the boot... filled with around 80GB of music.
It works ok, but the only problem is that the headunit spends 5 minutes scanning thru all the songs everytime I turn it on! This is quite annoying, especially for shorter journeys...
I know there are a few others on here using a USB headunit, and I was wondering if there was any way around this problem? Maybe defrag the HD or something to make it scan faster?
Also, sometimes the songs are out of order, it will often play 5,4,3,2,6,7,8,9,1 for example.... I think it plays the songs in the order they were copied across... I was wondering if there is some utility to modify the dates on the files do that they play in the right order?
	 ), copied over the 80GB of music again, took it back out to the car, connected it all up, and it worked (after about 5 minutes of scanning thru all the songs)...
