I wish to board my loft although have a few questions if someone could kindly answer:
Would these be OK?
http://www.diy.com/diy/jsp/bq/nav/nav.jsp?action=detail&fh_secondid=9276266&fh_location=%2f%2fcatalog01%2fen_GB&fh_search=loft+board&fh_eds=%c3%9f&fh_refview=search&ts=1195005156117&isSearch=true
Am I best to screw or nail to the joist?
I would have thought screws, if so, what size?
There is currently some VERY VERY thin insulation between the joists, could I put some new insulation on top of it THEN board over the insulation?
I need a deecent cordless screwdriver for doing this. Have a budget of about £100. Would this be acceptable:
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=87486&ts=05835
Also, I need a cheapish infra-red "Tape" Measure to work out the amount of flooring as dont want to be clambering over the joists with a tape measure.
Second thoughts, one with a range of more than 6 meters is over a £100.
Thanks for any advice.
Would these be OK?
