 - 21 Jan 2007
Hey,
I've got my watercooling setup all ready to go, but I've run into one problem with it. The pump seems to be circulating small air bubbles. If I do the switch on/switch off thing then the bubbles slowly dissipate, but as soon as I leave it running for about 30 seconds or so, the bubbles start to reappear. The reservoir makes weird gurgling sounds and the bubbles start travelling up the first tube again.
For a pump I'm using the Laing DDC with Alphacool top and res bay, which I figure is the problem. As the water churns about from having it thrown at speed into the bay, the pump is sucking down the occasional bits of air and blowing them back into the tubes.
Is there any way of stopping this? I figure if I can't sort this out then I'll put in a T bend, strip out the res and use the Laing purely as a pump. It just seems a bit weird that this wouldn't have been designed out of the whole setup. Maybe the water is just travelling too fast? Is there a way to slow it down?
Any help would be appreciated, I'm at my wits end here. On a side note, however, I put the loop into the computer for a test run, only plugged in the necessary stuff - motherboard, graphics card - and in the BIOS I was getting a rather satisfying 28-32c temperature reading. This frankly amazes me, as previously on air it was sitting a good 10-15c higher. Awesome.
For reference: Res/Pump -> GPU -> CPU -> Rad -> Res/Pump
I get a lot of bubbles coming out of the GPU - EK8800 - they appear like a small stream travelling down the centre line of the tube and into the CPU block.
