UKFSN (Entanet) Really slow?
i think the new segment has improved things although central 7 due feb is going to make things loads better and with a another segment due in 6 weeks should get better all the time.
It has improved things, speed wise im not so sure though, still getting around 2.5mbps during peak times, and even in non-peak times torrents are downloading at 100-150 odd kbps. could be faster? Are they throttling?
no enta dont throttle their network it slows down with off peak downloaders timing downloads for off peak usage.
Thats what im saying, even downloading during then day when all things on the front line are quiet and there is plenty of capacity, HTTP downloads are OK torrents are slow, a lot slower, used to get around 300-400 on torrents, these days im lucky if i hit 150kb/s.
Not using the default ports either, using a range of high random ports.
enta don't throttle torrents. :p
screenshot taken just now
Wow, I havnt seen them speeds on my torrent client in ages! Im going to have ago at re-configuring my torrent client I think and try some new ports to see if I can get better downstream performance.
are you sure it's not just the torrent your downloading? as for ports, i just use the random one chosen by utorrent and let it use upnp to open the port on my router. :)
For torrents its all about the seeders speed, I got a private Trance tracker and I can easily max out my connection from there as there seem to be a few people with Mbit connections there and you pull like 200k+ from one person.
Changing ports etc wont make any difference to your speed on Enta net as they don't throttle.
If you feel your connection is slow use the entachoice site to check your central and how crowded it is and disconnect till you find one thats not overcrowded.
