I finally figured out how to squeeze an Enermax Galaxy into a P182.
Take out the bottom fan spin it round and refit on side of HD's dont forget to turn the fan around on the mounting as well to keep the flow going the correct way.
Took about an hour to get it in with out scratching anything and it is really a tight fit you need to bend the internal fan mounting plate a little to get the PSU past it and into the case.
