Wouldn't work on a crocodile.
It'd clamp on your arm and death roll, then you would have no arm
That's sharks init?
apart from choking it out maybe, if that's even possibe?
If it grabs hold of you there is Nothing you can do to get it uff because its jaw will just lock and will not release.
They aren't very big though, I can pick one up and slam it against a wall until it does let go... or my arm falls off
Also the whole jaw locking thing is a myth.
A Pit Bull named Aidan was measured at having a bite of 130-235 pounds
Id take the safe option and run/climb over/up something.
Then throw a brick or something at it
It may be a myth but could you get this off your arm?
The bull was flinging the dogs twenty feet away in the air, but the dogs just kept coming back - it was basically a question of who would get tired and give up first, the bull or the dogs.kick/punch in the nose. Although proper dogs are hard as nails, not those rat dogs and the like.
One of my mates used to have a Japanese Aketa(sp) I used to wrestle with it and it was very strong (it didnt bite properly either as it knew it was playing)
