Bit longwinded this but if anyone has experience with USB boot disks....
- I've no floppy drive so I'm forced to try flashing a video card via USB stick.
I used 'HP USB Disk Storage Format Tool' to create the usb boot disk, no probs
Then I choose usb as primary removable disk in bios (instead of floppy), and then select it as primary boot disk. THis works perfectly except.....
If I boot regularly without the USB stick in the drive, primary removable disk reverts to floppy. It stays stuck on floppy even if I put the USB stick back in and reboot.
Basically it means I have to manually change it in the bios every time I want to boot from USB!!
I can't see a way round this
Any takers
Any takers
