- 18 Oct 2002
- Manchester
... Is that your once rep max for your bench? Your lift some big weights but the bench seems out of place
You must have some meaty calves by the way![]()
Some of my lifts are out of balance due to the injuries I've picked up this year. Also got hit by car last autumn that tore my leg muscle and knackered my lower back putting me out for action for months.
Pulled my hamstring at football 3x times this year which has severely hampered my deadlifting.
Yeah always had strong calves thanks to lots of football, running, etc.
Same here. Biggest set DB's at my gym are 95lb (43kg) to go heavier I have to use the spinlock DB's with free weights. These are even worse for getting into position as the bar sticks in my thigh... you should see the bruises they leave once the weight goes over 50kgNice numbers, but specifically you're lucky to have the above, dumbells top out at my place at 40KG
I can do 8x36/38/40 now, which was my xmas goal, shame I have to head back to a bar to get heavier. (And pushing bars is very different).
