- 8 Oct 2007
Can someone help me and tell me where im going wrong, is this is correct to oc my cpu?
Amd Athlon 64 X2 3800+ (socket AM2) 2000Mhz X10Multi Bus - 200 Ht Link 800
Asrock A-liveSATA2-Glan
Corsair Value Select 1Gb X 4 DDR2 4300 266mhz. 4-4-4-12-15 1.8V
G-force 7950 Gt GS. Stock 580/750 Oc'd to 640/850
Hiper 580 Watt Sli Edition
Windows Xp Home 32 Edition (i know about the ram
3.3gig)
2.2ghz 220mhz X 10 - 2200mhz (2.2ghz) Stock is 2.0ghz.
Any higher than 2.2 it becomes unstable
At stock my processor is using around 1.185 Volts, it can go to a max of 1.250. I leave the voltage on Auto to use how much power it needs and i up the Core Speed by around 20, after 20 even 25 it just crashes when booting up or when i begin to "Stress" the cpu by trying to load something.
I also have Core Temp up and the cpu temps arnt even that high enough for it to crash IMO. Stressed at 2.2 it heats up to around 46oC
Thanks For The Help,
Paul.
3.3gig)2.2ghz 220mhz X 10 - 2200mhz (2.2ghz) Stock is 2.0ghz.
Paul.
