I have the Noctua on an EVGA 680i board with a QX6700 and I must say I'm less than impressed with it's performance.
Stock speeds, I'm getting 49 degrees at idle.
The more I read, the less I think it works well with quad core CPUs...
Has anyone used a Noctua NH-U12F CPU fan on an Asus P5N32-E SLi motherboard with a quad core Q6600?
Just want to check if it fits (due to the copper heat pipes on the mobo) before I place an order.
49 idle is NOT a good temperature, even for a QX6700.
my Q6600 at 3ghz at load is at 51 degrees.
I'm not alone in being more than happy with Noctua.
Apart from performing very well they are very quiet.
I've had my Q6600 up to 3.6 GHz, Stress tested for 8 hours with Prime95 and the highest temp on any core was 66 C - Noctua heatsink.
If I was building another PC tomorrow it would have a Noctua on it.
It doesn't matter what piece of kit you consider, some will be happy and some won't - for a variety of reasons.
Have a look at the Quad Database - Link.
The best performances come from water cooling but amongst the air coolers there is more than one Noctua.
