- 12 Dec 2005
Hi,
I'm planning my next PC project. I intend to take the "plunge" into Water Cooling and I am looking for a suitable case.
I need a large tower case with the PSU mounted at the top, above any water leaks, and with plenty of space at the bottom, below the MB, for pumps, etc.
This is also going to be a very quiet PC, so I want a case with solid panels and only the minimum of ventilation & fans. Ideally just a single 120mm fan on the rear panel and, possibly, another at the front to cool the disks.
The case should accommodate an ATX motherboard, at least 5 x 3.5" disk drives, ideally with some sort of vibration damping, plus a floppy disk drive and a couple of CD/DVD drives.
Cost wise, err, functionality is more important than price (within reason). Colour is not a major consideration either, but black would be good.
Thanks in anticipation
John
John
