Im stable at 3.42 @ 1.45v
Tried to get to 3.6, upped voltage to 1.475 as Orthos was only lasting a few mines, on CPU test only, but then started to BSOD
Whats the max and settings other people have?
Cheers
Quickly rising to 60+c on load.
Seeming that you idle temp isnt much lower, what about your load temp? cant remember if you posted it above?
my cpu is stable 1.425 @ 3.4ghz....then suddenly requires 1.55 to be stable at 3.6ghz.....
Mines running as per sig. Only need 1.375 volts through it
Its running at 425x8. Motherboard didnt like the x9 multi passed 3.2ghz.
that idle temp of 22c sounds very difficult to believe unless your room is very, very cold
sorry buddy but what those have to be mis-reported, unless it's like 2c in your room.
What does it say in the bios?
I highly doubt it, with my thermaltake soprano case my idle temp was 35C with the Antec 900 it's now at 22C idle.
The thing is, it's really a physical impossibility unless your ambient temps are close to freezing.
There's no way an e6600 can idle a few degrees above ambient with an air cooler
I get about 28-30c idle and 55c full orthos load
but you haven't said anything about BIOS temps...only speedfan temps which are notoriously innacurrate.
