That shouldn't be the case, must be something wrong with your installation of Windows or your motherboard drivers.
No, its been fairly reliable across all my AMD and Intel setups.
I must point out as I kept trying to before, that under normal use, this just was never an issue, but under extreme use, the AMD just kept chugging along.
Read my post propery, I said I was fed up with AMD back then not now, my reason was because they led the enthusiast market with Athlon 64, they charged a premium which I fealt took the P.
Before Athlon64 when intel led, they were tarred with the same brush I agree, but I was saying that I liked intel at the moment because their chips are fast and they are cheap, thats all.
Ok, I accept what you are saying... I have double-backed and re-read it, and I can accept that I read it incorrectly.
That is rubbish I think
Say what you like.
I did some tests ( Extreme ones I admit ) and found some interesting results. Many others did similar tests and found similar results, and since then, there has been dozens of Professional bodies also running similar tests and still finding the results the same as my own.
I got fed up before in pointing people to the many many web pages that also show similar results so Im not going to bother wasting my time this time round.
Besides... If the Intel was THAT much better than AMD, then why are Intel to be taking up AMDs ideas on a lot of things and implimenting them into their own CPUs to regain some of the speed that AMD have over the intel in certain areas?
